JHZR2
Staff member
Car is a 2004 Saab 9-3. One of the strut mounts/bearings is binding when I turn the wheel, and I can feel and hear this in the spring.
The car has around 72k miles on it, and hasnt gotten a ton of use the last few years besides long road trips. I love the car, it rides and drives well and efficiently, and I dont have any plans to get rid of it.
So... One way or another I need to fix this, as I dont want a handling or safety issue. Question is, with that mileage and age, do I just replace the mount? Do I replace both mounts though one is OK? Should I replace the struts too? The springs were replaced a few years back due to a saab recall where some were not properly surface finished and could fail and break.
Currently on there are Sachs OE struts. They are twin tube (I always like Bilsteins personally). Bilsteins are a little more than twice as expensive... not sure theyre worth it. Is there a good test for modern struts? The car doesnt bounce or ride funny... But some say that 60-70k is all one gets out of typical shocks and struts...
Also, if I should replace them, I can get KYB, Monroe, Sachs and Bilstein. Recommendations? Not sure if the autozone Sachs are the same as OE.
If I do the fronts, should I do the rears as a matter of course?
How tough is this job to do, i.e. replace a strut? What is the typical time commitment for a vehicle on jackstands in the driveway? Vague question I know, and it is skill dependent... But just typically, how long has it taken you to do this job?
Thanks!
Thanks!
