I've been looking for a couple of years, for just the right car. The Jaguar X-Type I've been driving, while a good car, is just not my kind of car. I looked at 2008 and later Corvettes, 370z, S2000 and others. My favorite was a 2008 Corvette Convertible w/manual trans Z51. But the price was out of my reach.
I found a 2004 S2000, very low miles, near perfect cosmetic shape, with an "Inline Pro" Stage-1 turbo kit installed. It's configured to make 17.5 pounds of boost on a relatively small turbo (for good midrange torque) . It looks completely stock, with the exception of a large, but stock looking exhaust. And if you look carefully, the intercooler is visible in the front. My plan is to carefully remove the intercooler and exhaust and paint the visible portions flat black. Just to keep the clean look.
It will need a bit of tuning to get it "just right" as there are a couple of things that warrant attention. I'll get it dialed in. I'll need to reposition the air filter to a cooler location and work with the blow-off-valve. As I don't like the noise. Nor do I like the blow-off-valve open under part throttle conditions. As it reduces throttle response.
Other than that, it really drives like a car should. Quick, responsive, agile, comfortable and reasonably quiet. Accelerates properly when asked.
Inline Pro Stage 1 turbo kit
600HP intercooler
3 inch, turbo back, dual, oval tip (like stock) exhaust with high flow cat
AEM engine computer (not just a tune)
larger front sway bar
3mm head gasket (for lower compression)
Remote oil filter (probably should add cooler too)
big injectors
6 puck clutch disk and pressure plate
ball bearing turbo upgrade
Dyno tuned by Inline Pro
Probably around 400HP at the wheels, others with this setup make 417, 425, 405, and so on. Seems to be fairly close to 400. But many of those guys don't run cats. We shall see.
600HP intercooler
big injectors
