NOACK volatility ratings
by Rat407
02/27/17 07:29 AM
Engine shots - 07 Accord @ 100k miles
by AccordK24
02/27/17 06:39 AM
Fender bender city
by CourierDriver
02/27/17 06:07 AM
Schaeffer's representatives
by FowVay
02/27/17 04:02 AM
TRADE: Valvoline 5w20 SM dino (Orange County, CA)
by zorobabel
02/27/17 12:43 AM
How do I identlfy an Exide battery?
by Chris142
02/26/17 11:48 PM
Has anyone replaced iPhone battery?
by maverickfhs
02/26/17 09:40 PM
Replace belt tensioner or just the pulley?
by rationull
02/26/17 09:11 PM
Renewing Black trim
by Eddie
02/26/17 09:08 PM
Anyone still use Durablend?
by car51
02/26/17 08:58 PM
Schaeffer's 9000 5w40 - '03 TDI top end pic
by Alex_V
02/26/17 08:22 PM
What's up with all the storms forming at night?
by motor_oil_madman
02/26/17 08:21 PM
Costco battery warranty
by Kool1
02/26/17 08:05 PM
Just did first oil change with microgreen filter
by FlyingTexan
02/26/17 07:41 PM
Differential oil Infiniti G37x
by chartkor
02/26/17 07:20 PM
10w40 oil Not ILSAC Approved?
by doolah02
02/26/17 07:06 PM
Triple A....worth it or not?
by crookedaxle
02/26/17 06:58 PM
Under valve cover shot
by Ben Boyle
02/26/17 06:21 PM
how raise the idle speed on a mower?
by edwardh1
02/26/17 06:04 PM
Switching from Synthetic to Dino
by beadvised
02/26/17 05:45 PM
jteck75, jviss, xsboredom, Taylorm, banjobilly
60661 Registered Users
75 registered (beanoil, 4WD, 86cutlass307, AEHaas, adamrc, Bandito440, 10 invisible), 1266 Guests and 12 Spiders online.
60661 Members
66 Forums
261623 Topics
#3251304 - 01/17/14 02:48 PM 2013 6.7 F350 Delo 5w40 7500mi
BeerCan Offline
Loc: FL
2016 Ford F150 3.5 EB
2015 Hyundai Genesis 5.0
2012 Hyundai Genesis 3.8
2015 Ford Mustang 2.3 EB
1999 F350 7.3L PSD
#3251505 - 01/17/14 06:42 PM Re: 2013 6.7 F350 Delo 5w40 7500mi [Re: BeerCan]
clinebarger Offline
Loc: Fort Worth, Texas
Do you do a lot of stop & go driving, Long idle time?
How often are the regen's, DPF regeneration requires extra fuel to be injected in the cylinder that will dilute the oil with fuel
2001 Chevy Camaro 6.2L/4L65E, Former V6 car
2010 Toyota Corolla 2ZR-FE/Auto
#3251799 - 01/18/14 04:30 AM Re: 2013 6.7 F350 Delo 5w40 7500mi [Re: BeerCan]
dnewton3 Offline
Loc: Indianapolis, IN
Wear isn't terrible, but the Al uptick is perplexing. Other parameters not bad either.
I don't really know what you'd run a syn at those short OCIs ... The fuel dilution is the issue here; no syn is going to stop that.
This rig accumulates a lot of miles; probably will have 40k in a year's time? Question is this: what kind of service does it see? If it idles a lot, that would explain the dilution from (likely) frequent regens. If this rig hauls loads on open roads often, coming up to temp and staying under load, then I'd worry about a leaking injector.
Edited by dnewton3 (01/18/14 04:34 AM)
Conventionals vs. Synthetics isn't about which is "better"; it's about which lasts longer, while assuring safe operation, in relation to cost. Any product can be over or under utilized. The same applies to filters.
Make an informed decision; first consider your operating conditions, next determine your maintenance plan, and then pick your lube and filter. Don't do it the other way around ...
#3251805 - 01/18/14 05:01 AM Re: 2013 6.7 F350 Delo 5w40 7500mi [Re: BeerCan]
dustyroads Offline
Loc: upstate NY
I believe this was your first go 'round with the delo (?).... but wow it looks just like lubrication engineers oil used previously (speaking of the add pack).
Maybe the aluminum spike was due to change in oil chemistry (?)
Have you talked to or read about other 6.7 owners having the same fuel dilution issue? If you're working it, seems as though it shouldn't regen too much. So I wonder if it is maybe an injector related problem.
2011 Taurus sel
PPPP 5W20 and Fram XG10575
#3251941 - 01/18/14 08:59 AM Re: 2013 6.7 F350 Delo 5w40 7500mi [Re: BeerCan]
BeerCan Offline
Loc: FL
Truck does not idle long. It is used as a DD but I often tow heavy. Regens are sometimes every 100 mile and sometimes every 400 but avg around 150-180. I often use B5-B20 so that contributes to fuel dilution I am sure.
I have now switched to delo 15w-40 to save some cash
I have an appt with the dealer to check the injectors, I will report back with the findings.
What perplexes me about the Al is that Polaris reported my Ecoboost doing the same exact thing
EB UOA
Al shot up on 1 report and then went back down the next. Strange coincidence I hope.
Edited by BeerCan (01/18/14 09:00 AM)
1999 F350 7.3L PSD
