I like OEM Toyota/Denso filters. The K&N is average filtration, excellent construction quality, and higher flow for modified engines with oversized oil pumps. The Mobil 1 filter is made by the same company as the K&N oil filter (Champion Laboratories), but made for normal flow and finer filtration. For about the same filtration as the Mobil 1 filter but lower cost, I'd get the Purolator Pure One. I use Toyota/Denso filters. I've been using ones with the fiberglass mat media (not really yellow foam), and when those are gone, I'll try the ones with paper-type pleated media.
Ken
