The meter on my 10amp (Schumacher) charger is out: when charger's clips are connected to a 12 volt battery that's a little low, what should the voltage reading be between the two battery terminals?
I don't think I can read actual amps output with the test device I have without opening up the charger itself, but the voltage reading I'm now getting hooked up as above is about 16 volts. Needless to say I don't have the battery cables hooked up.
Does it appear I'm actually charging the battery to you guys?
Thanks in advance!
Thanks in advance!
