GL5 with friction modifiers
Quite a number of manufacturers either as a conventional diff or a center diff for 4WD. In fact a Torsen diff equipped F1 car won a GP at the Hungaroring some years ago.
Originally Posted By: redbone3
I recently put Peak Limited Slip Synthetic 75-90 GL5 gear oil in my '95 Miata (Thorsen) axle. I understand the Thorsen axle doesn't require the LS oil. My thought was any rear axle is going to have very similar requirements for lubrication (still has a ring and pinion gear for example) so the LS type lube would be fine. Am I missing something?
I think LE1605 DUOLEC would work very well in your Miata Torsen LSD.
