Whos using 15W40?
I only run delvac 1300 15w-40 in my 5.9l cummins in my truck. I'm thinking of switching over to the delves oil in my Kubota that calls for 10w-30. My car even with the 203k mi it still doesn't really use enough oil for me to thicken it up.
I'm using Chevron Delo 15w-40 in my '71 VW Bus (7qt capacity with full flow, by-pass filters, and sump). The oil I got is the pre LE version. I have used the 15w-40 oils in many air-cooled VW's. A bit off topic but stumbled onto the Shell Rotella T 10w-30 oil here in Los Angeles' Pep Boys and am using it in a new friends stock '74 Karman Ghia 'vert that has used Pennzoil yellow bottle (PS: thanks Shell). Bill
I also have a "beater" '74 bug which has an engine which has been documented, on previous owners repair orders, to have overheated and I use the HD oil. I am using 15w-40 in the cooler months and a straight 40wt during our So Calif summer.
I have a couple of customer/friends that own nice older VW's and I have used the 15w-40 oil in those also.
PS: These dual-rated oils are so nice to have available for the older flat tappet air-cooled cars that I own and service. Bill
Premium Blue 15-40 is used in my 3.8 GM as a make-up oil, when its the easiest thing to grab from my leftovers.
I agree with Bulwinkle's post. I worked for a large gov't fleet here in So Cal and for decades had used the 15w-40 oils in everything, to include the Ford modular engines. Ford did not like this use of the heavy oils but I can say we never had an oil related issue. The last few years we were kinda "encouraged" to use the recycled fleet oils. Bill
I mix it with some HD 20w50 oil in the Harley and use it straight in my engine in the John Deere lawn tractor. Also goes in the other small engines outside.
Originally Posted By: bullwinkle
A newer 460 would be 5W20, older one likely 5W30-it would use a lot less if it had 15W40 in it (at least an older, worn U-Haul motor).
In my 460 (Continental) I had, I ran 10w30. Did perfect.
used in my 2002 camaro LS1 since new, 70k miles now, still have 40 psi at hot idle 800 rpm.
used in my 2005 altima during summer to 40k miles till i sold it
used in my boat, 2002 3L merc i/o
being using it in my 2006 sierra with 8.1L motor, has 75k miles now.
used in 2012 outback during summer.
Oil thinning and what is really going on: Its in the details on the Home Pages of BITOG----------------------------------------------------------------------------------------------------------
We left off discussing that a 0W-30 grade oil is not thinner than a 10W-30 oil. They both have the same thickness at operating temperature. The 0W-30 simply does not get as thick on cooling as the 10W-30. Both are still way to thick to lubricate an engine at startup.
I have heard several people say that Porsche specifically prohibits a 0W-XX engine oil, that it is too thin. Now here is the partial truth I spoke of earlier. We will discuss multi-grade oils. Earlier we said that a straight 30 grade oil has a thickness of 10 at the normal operating temperature of your engine. The multi-grade oils 0W-30 and 10W-30 also have a thickness of 10 at 212°F.
The difference is at 75°F, your startup temperature in the morning.
Oil Type Thickness at 75° F Thickness at 212° F
Straight 30 250----------------------------------10
10W-30 100 10
0W-30 40 10
Straight 10 30---------------------------------- 6
( Oil Type varying Thickness )
Now you can see that the difference between the desired thickness your engine requires ( = 10 ) is closest to the 0W-30 oil at startup. It is still too thick for normal operation. But it does not have far to go before it warms up and thins to the correct viscosity. Remember that most engine wear occurs at startup when the oil is too thick to lubricate properly. It cannot flow and therefore cannot lubricate. Most of the thick oil at startup actually goes through the bypass valve back to the engine oil sump and not into your engine oil ways. This is especially true when you really step on that gas pedal. You really need more lubrication and you actually get less.
Note that a straight 10 grade oil is also too thick for your engine at startup. It has a thickness of 30. Yet at operating temperatures it is too thin having a thickness of 6. It needs to be around 10. The oil companies have added viscosity index improvers or VII to oils to solve this dilemma. They take a mineral based oil and add VI improvers so that it does not thin as much when it gets hotter. Now instead of only having a thickness of 6 when hot it has a thickness of 10, just as we need.
The penalty is the startup thickness also goes up to 100. This is better than being up at 250 as a straight 30 grade oil though. Oil with a startup thickness of 100 that becomes the appropriate thickness of 10 when fully warmed up is called a 10W-30 grade motor oil. This is NOT as thick as a straight 30 grade oil at startup and it is NOT as thin as a straight 10 grade oil at full operating temperature.
The downside of a mineral based multi-grade oil is that this VII additive wears out over time and you end up with the original straight 10 grade oil. It will go back to being too thin when hot. It will have a thickness of 6 instead of 10. This may be why Porsche (according to some people) does not want a 0W-30 but rather a 10W-30. If the VII wears out the 0W-30 will ultimately be thinner, a straight 0 grade oil. When the VII is used up in the 10W-30 oil it too is thinner. It goes back to a straight 10 grade oil. They are both still too thick at startup, both of them. The straight 0 grade oil, a 5 grade oil and a 10 grade oil are all too thick at startup.
This is just theory however. With normal oil change intervals the VI improver will not wear out and so the problem does not really exist. In fact, oils do thin a little with use. This is partly from dilution with blow by gasoline and partly from VI improvers being used up. What is more interesting is that with further use motor oils actually thicken and this is much worse than the minimal thinning that may have occurred earlier.
Synthetic oils are a whole different story. There is no VI improver added so there is nothing to wear out. The actual oil molecules never wear out. You could almost use the same oil forever. The problem is that there are other additives and they do get used up. I suppose if there was a good way to keep oil clean you could just add a can of additives every 6 months and just change the filter, never changing the oil.
When the additives wear out in a synthetic oil it still has the same viscosity. It will not thin as a mineral oil. The fear that some say Porsche has that oils thin when the VII runs out is not applicable to these synthetic oils. These oils will always have the correct thickness when hot and will still be too thick at startup as with all oils of all types, regardless of the API / SAE viscosity rating.
Automotive engine manufacturers know these principals of motor oils. They know there is thinning or thickening that will occur. They take these things into account when they write that owners manual. Mineral oil change recommendations will generally include shorter time intervals than those of synthetic oils.
The reality is that motor oils do not need to be changed because they thin with use. It is the eventual thickening that limits the time you may keep oil in your engine. The limit is both time itself (with no motor use) and/or mileage use. The storage of motor oil in your garage, particularly mineral based oils, slowly ages the oil limiting its use later. Do not store huge volumes of oil in your garage that is exposed to extremes of temperature.
Chapter Three
Chapter One
Tags: Motor Oil
Motor Oil 101
Motor Oil 102
Motor Oil 103
Motor Oil 104
Motor Oil 105
Motor Oil 106
Motor Oil 107
Motor Oil 108
Motor Oil 109
Motor Oil 201
Motor Oil Mid-Term Exam
Motor Oil Final Exam
46284
64
196907
3046532
Users
Forums
Topics
Posts
Max Online: 2449 members
Occurred: 05/13/13 01:57 PM
Hi,
CourierDriver - misinformation abounds. Your Reference said this:
"I have heard several people say that Porsche specifically prohibits a 0W-XX engine oil, that it is too thin."
Hog - or Pig wash......
I use it from Late April until late November. I love the robust add pack and the cheap price. A while back I picked up like 5 or 6 gal for $8.99 ea. Delvac. 7 months out of the year (in Colorado) I use it in: 1. Buick Rainer 112k. 2. Moms 03 Tahoe. 3. All my cycles.
The Bitog data i get from the home page is stuff I believe is written by someone with a lot more brain cells then I have got, that is why I post it. Now if some data has changed, the folks that run this site will know, but for now, the high tech stuff I read about oil is from the university data on the home page.
ok, thats my 2 cents worth...............
You don't need to reference the writing of Dr. Haas (who is a doctor, not a lubrication engineer, though he has certainly put a great deal of time and effort into his writings and they are excellent references even if not quite 100% accurate) when speaking as to the Porsche oil specs because Porsche has their own approval process and maintains a list of approved motor oils.
Here's a link that has the approval list from 2007:
http://forums.pelicanparts.com/porsche-9...-07-1701-a.html
You'll note there are MANY oils on that list that start with 0W-xx
Also, I think some of your oil theory may be a bit mixed up. Instead of re-hashing it here, please feel free to look at this thread:
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1133544&page=5
Where I speak with respect to what you are attempting to convey in your earlier post.
Ran 15w40 in my chrysler 300m 3.5 one oc. Kinda dumb story i double gasket the oil filter and lost all the oil and all i had on the shelf was rotella. In it went! No issues whatsoever, it was december even. Prob 4qts rotella 1 quart mobil 5w30. My ford diesel mechanic buddy runs it in any engine not sohc or dohc says it wont hurt a thing in a pushrod engine. Now OHC is a different story.
I have heard some people say that the longer passage to the cam is a problem with 15w40, but I don't know if having an OHV engine eliminates the risk. Rocker arms, valve lash caps, and pushrod tips also need to be well oiled, and oil has to be pumped upward the same distance as it would in a SOHC or DOHC engine.
I have read conflicting stories on this subject when I frequented Saturn message boards. Some people would post a UOA that showed low wear with 15w40.
In florida you could prob get away with it no prob, but in OH at 5*f it is awful thick when you crank the old SBC with 5 quarts of 15w40. You can hear the starter complain.
