OK, I've had it. I have a metallic, dragging noise on the rear end of my 2004 Silverado, 2 wheel drive, 3.42 limited slip. Changed out the rear pads and rotors with no change. The emergency brake shoes were good when I changed out the rotors. They had plenty of friction material left on them.
Sometimes, when it seems louder than usual, it will decrease in volume when I lift my foot off of the gas pedal. It will also change in tone when the suspension compresses and decompresses (like a dip in the road). When I put it into reverse to back out of the garage, there's no play in the drive line, so I don't think it is a u-joint, there's no clicking either in a turn.
I lost a u-joint on the Sierra, and this doesn't seem the same at all.
My neighbor thought that it sounded like it was coming from the passenger side. My best guess at this point is to suspect an axle bearing?
