JHZR2
Staff member
When they installed FIOS internet a while back (net and phone came out cheaper and way faster than old DSL, and the discount they gave is supposedly permanent - good deal), the installer took the fiber signal in and then put out a coax cable that fed directly to the router/modem.
The main run from the main box to inside of the house wasn't quite long enough and so there is a little extension on it to get to the current location.
We are moving around the arrangement of the room where the router/modem was, and want to put it elsewhere in the room, probably 20 feet away.
Now the cables both are PPC Perfect Flex 6 series, but no idea what kind it is. Quad shielded? Tri shielded, etc. No real indication on the insulation printing.
So my options are to leave the router and modem in the basement, and run cat 5 to the two first-floor locations where I sometimes need a wire versus wifi, or to extend with Coax the run to the router/modem, and then put it upstairs where we would like to relocate it.
The wifi signal reaches the second story of our home well. Haven't tried in our walk-up attic, but think it will reach well enough.
So whats the best way to go, and if coax, whats the product I want?
