I picked up a set of used Mopar wheels to mount my winter tires on. I noticed while cleaning them up that there is a bright yellow sticker in the drop well of each rim.
Anyone know if this is for match mounting? I have read that Chrysler match mounts their wheels and tires at the factory so this makes sense but I have yet to find any info relating to the wheels. The Yokohama tires that I am ordering should have the marks so I would like to have my son match mount them if that is indeed what these stickers indicate. The yellow mark on the Yokohama's is for weight but it seems the valve stem hole typically indicates weight and a mark or sticker would indicate radial run out, which is red on the tire.
