I was wondering about those blue bottles of washer fluid that go down to 0* F containing methanol. We never get cold wnough to need even that low protection.
Or RainX.
I have read that the pink RV antifreeze when it gets hot is destroyed and turns brown.
There is a company that sells an expensive lifetime antifreeze which must not be mixed with water. That also allows for higher engine operating temp with a higher temp thermostat which you can not buy could increase your mpg.
I think the blue washer fluid would work, didn't years ago some antifreezes used alcohols? Rust might be an issue so then put in an anti rust water pump lubricant.
I have before run plain water with the antirust additive,
Or RainX.
