Rust locked bolt/stud. Rust disolver
Originally Posted By: 05LGTLtd
So did you get the valve/studs separated?
No, still spraying. Not in too much of hurry as I have not got the SSBC brake pressure gauge set yet.
Use a ball tip flame on the nuts then use an impact on med setting, they will come right off.
Soaking it in penetrant like you did and using an impact on low-med will probably work fine without heat.
