Originally Posted By: edyvw
Originally Posted By: SteveSRT8
Originally Posted By: Mykl
So basically, add track days to your maintenance schedule. If four 20-25 minute sessions flat out on a race track doesn't clean those valves, it just isn't going to happen without removing the intake manifold.
I love this idea. See you at the track for some valve cleaning!
Or, you come to my place and try to run as fast as possible to Pikes Peak, like I do sometimes. If you do not overheat engine climbing to 14,110ft, the valves for sure will be cleaned
Then, on the way back you can test how good your brakes are and whether your brake fluid is OK!
Sounds like fun. The only problem I would have is my car is naturally aspirated so the altitude would kill my power. But the brakes are ok, they'll hold up (16 piston fixed Brembo system).
