Goodbye Encore, hello Soul!
by csandste
04/21/18 12:34 PM
7.3 drain plug torque
by mobilaltima
04/21/18 12:26 PM
'09 Kia Sedona - to change or not to change (oil)?
by Number_35
04/21/18 12:19 PM
I Think Spring Is Finally Here
by Warstud
04/21/18 11:48 AM
NAPA GOLD 7055 UN USED CUT OPEN
by car51
04/21/18 11:26 AM
Broken Cat
by Stelth
04/21/18 10:32 AM
How often do you use your moonroof?
by mclasser
04/21/18 10:29 AM
Weird Electrical Issue.
by George7941
04/21/18 09:35 AM
Ever puchase movies from cable provider?
by ZZman
04/21/18 09:31 AM
Mann HU 711/51 X oil filter for Miniís $6.50 Amzn
by 1JZ_E46
04/21/18 09:30 AM
M1 Oil For My Trucks Engine
by BlueOvalFitter
04/21/18 09:30 AM
Toyota SofTex upholstery
by CincyDavid
04/21/18 09:09 AM
Castrol Dexron VI $5 QT at AA
by The_Cams
04/21/18 08:41 AM
Liqui moly engine flush
by gallydif
04/21/18 08:27 AM
Uneasy about Bosch Cartridge Filter
by tc1446
04/21/18 07:36 AM
Harvest King 0w20 Full Synthetic
by oilstudent24
04/21/18 07:22 AM
oil spec.
by ernied
04/21/18 07:03 AM
Great dog story to start your day!
by AZjeff
04/21/18 06:51 AM
BITOGers in the wild west
by Shannow
04/21/18 03:54 AM
'10 Wrangler 5,350 Miles Cam2 5w30 Synavex
by montero1
04/21/18 03:31 AM
puma4440, zeroyon223, wade12345, rdatman, mowermon
64805 Registered Users
78 registered (andyd, alphadog, Astro14, 2015_PSD, aquariuscsm, 1JZ_E46, 4 invisible), 1784 Guests and 46 Spiders online.
64805 Members
68 Forums
282065 Topics
Page 1 of 2 1 2 >
#3176971 - 11/03/13 09:15 AM Best cleaner to flush a heater core
nomochevys Offline
Loc: Ky
Still trying to work out some kinks. I have heat but its nowhere near what it should be. Truck is a 96 GMC Sonoma 4.3. I am pretty much convinced the heater core is plugged up to some degree. What is the best thing I can use to help clean it out with?
#3176984 - 11/03/13 09:29 AM Re: Best cleaner to flush a heater core [Re: nomochevys]
Warstud Online   content
Loc: MIchigan
What have you done so far to get more heat?
#3176996 - 11/03/13 09:35 AM Re: Best cleaner to flush a heater core [Re: nomochevys]
spasm3 Online   content
Loc: North Carolina
I was under the impression that most heater cores today, always have flow. On older cars, the heat control shut off flow to the heater core and this caused gunk and build up. Are you sure the engine is up to temp, that the coolant is not low, and that the air flow blend door is working?
13 elantra 67k 5w30 QSUD
03 chevy avalanche76k synpwr 5w30
01 saturnsc1 185k synpwr rebuilt
17 mazda cx-5 2200 miles m1 0w20/0w40 mix
#3177005 - 11/03/13 09:45 AM Re: Best cleaner to flush a heater core [Re: nomochevys]
JHZR2 Offline
Loc: New Jersey
Citric acid flush and degreasing per the MB FSMs.
#3177009 - 11/03/13 09:47 AM Re: Best cleaner to flush a heater core [Re: nomochevys]
michaelluscher Offline
Loc: Staten Island, NY
If you've fully established that the heater core is plugged.
CLR would be quite good, a couple vinegar rinses after that would be good.
'06 Toyota Camry SE V6 3MZ-FE 96k
'01 Mercury Villager Estate VG33E 52k
'06 Ford Taurus SE Vulcan 60k
'13 Chrysler 300 3.6 Pentastar 202k
#3177016 - 11/03/13 09:54 AM Re: Best cleaner to flush a heater core [Re: nomochevys]
Sawdusted Offline
Loc: The Tropical Fine City
Eric the car guy did a youtube video on that some time ago. He used some cleaner plus compressed air to blow out the crud. I think it's a good video. Watch it if you get a chance.
2003 Lexus RX300, 1MZ-FE
2011 Volvo S60, 2.0T, B4024T6
#3177021 - 11/03/13 09:56 AM Re: Best cleaner to flush a heater core [Re: nomochevys]
nitehawk55 Offline
Loc: Ontario , Canada
Feel the heater hoses . If they are hot it's flowing , cool not .
05 Ford Five Hundred AWD 3.0 DOHC V6 CVT tranny
#3177032 - 11/03/13 10:05 AM Re: Best cleaner to flush a heater core [Re: spasm3]
yonyon Offline
Loc: NJ, USA
This is not so much the case. There are plenty of modern cars that use a heater control valve to shut off coolant flow to the heater core and also quite a few that use a heater control valve to negate the need for a hot/cold blend door.
This heater doesn't have that. If it's partially clogged, some sort of weak acid and lots of water should be used. If that doesn't work it's time for a new one.
#3177033 - 11/03/13 10:06 AM Re: Best cleaner to flush a heater core [Re: nomochevys]
Chris142 Offline
Loc: Deplorable in apple valley, ca
Air and water if its plugged up
02 Wrangler super-s 10w30
87 F250 proline 15w40
04 Tahoe super-s 10w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric edge 5w40
57 case tractor 15w40
#3177070 - 11/03/13 10:27 AM Re: Best cleaner to flush a heater core [Re: nomochevys]
PhillyJoe Offline
Loc: PA
I had little heat in my '07 Grand Prix. I flushed the system of dexcool and changed the thermostat. Heater hoses were hot to the touch. Still had little heat. New coolant was clear of gunk. Starting to think I had a bad core.
Read up on how to replace a heater core and thought, there has to be another answer.
Since one heater hose already has the flush "t", I cut the other and put in another t. I hooked up the garden hose to to one heater hose and squeezed the nozzle - out came rusty colored pudding. It ran clear in a few seconds. Then I hooked up the nozzle to the other hose to back flush. Surprisingly, more gunk came out. Hooked the hoses back to normal, refilled the coolant I lost, bled the system, and you could cook a roast in the car now.
#3177081 - 11/03/13 10:38 AM Re: Best cleaner to flush a heater core [Re: PhillyJoe]
crazyoildude Offline
Loc: New Jersey
i disconnect both hoses from the heater core and blast through water in one direction then the other a few times that works great
Check To See That The Oil Jugs You Buy Have The Exact Amount Of Oil In Them And Have An Inner Seal Under The Cap. I Use Mobil 1 And Fram Ultra Filters
#3177102 - 11/03/13 11:04 AM Re: Best cleaner to flush a heater core [Re: nomochevys]
mattwithcats Offline
Loc: Virginia
Disconnect the hoses and run some water from a garden hose in.
If this does not work, a teaspoon or two (max 3 teaspoons or a tablespoon) or plain dishwasher detergent.
No lemon scent, not orange scent.
Not CLR or anything acidic, heater core is very thin aluminum.
Rinse out the core, reconnect...
Edited by mattwithcats (11/03/13 11:05 AM)
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Purolator Synthetic PSL 14610, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
#3177119 - 11/03/13 11:22 AM Re: Best cleaner to flush a heater core [Re: nomochevys]
nitehawk55 Offline
Important to flush core in both directions .
#3177123 - 11/03/13 11:27 AM Re: Best cleaner to flush a heater core [Re: nitehawk55]
Garak Offline
Loc: Regina, Saskatchewan, Canada
And if there's a problem, how hard is it to change on this vehicle? If it's a relatively easy change (under 20 minutes on my F-150, hours upon hours on the old LTD), it isn't even worth playing with if it's clogged or weak.
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
#3177157 - 11/03/13 12:18 PM Re: Best cleaner to flush a heater core [Re: Garak]
nitehawk55 Offline
Feeling the heater hoses is a simple test just to give you an idea if the core is plugged or not . Totally plugged or almost they will be cool to warm compared to the engine hoses . If hot it should be OK but a flush is always the first method to try and clean out and it generally helps unless it's really plugged bad .Even if the hoses are hot it still is good to flush if you feel you are not getting the heat you should . Always the risk of there being a leak afterward though if lots of corrosion going on .
Make sure your engine is coming up to proper op temp or the thermostat is suspect .And of course check the operation of the heater doors or a flow valve if it has one .
How long ? no idea .
Edited by nitehawk55 (11/03/13 12:21 PM)
Page 1 of 2 1 2 >
