Originally Posted By: Tack
Thanks for all your replies, that is a pic of the head alright, so i guess the best thing to do is replace them, i already have a set of seals they came in the gasket set, so as they say bite the bullet and do it, the engine works so good, smooth and quiet, so now i will get rid of the start up smoke.....
I'll never disagree that replacing a worn part is a bad idea and if its a fiscal possibility then of course its a far better course of action than any magic elixir however not everyone has the mechanical know how to attempt to fix it themselves or its not a option in the monetary sense.
My suggestion was of course a band aid and would enable a person who isn't able to fix the problem right away some time to get their ducks in a row and fix the problem properly once they were able to do so.
I apologize if I came off rude,it wasn't intentional in the sense of being a jerk,I was implying that he didn't ask about a part replacement.
Anyways I know the motor oil saver to work in engines with leaks and valve seal problems which is why I suggested it. It costs 7 bucks a can which won't break the bank and it will enable a person to still operate their vehicle while taking steps to fix the problem properly.
He asked about an additive that would help his problem so I suggested one that will work and potentially save time and expense trying products that may or may not help.
Anyways quest I feel like I owed you an apology so I'd like to say I'm sorry.
