This has been on my mind since the last club Dyno run I attended. I witnessed many cars, not properly up to temperature, some dead cold even, and I know running very thick oil were pushed as hard as they could go on a Dyno. The result was, as expected, all vehicles drove away none the wiser.
So, as it is continually pointed out on here, cold (thick) oil and oil "thicker than necessary" will open the pressure relief valve. I think we can all accept it is not ideal, but really, is it that bad? Does it instantly equate to a loss of hydrodynamic lubrication?
Now my thoughts, It's more likely to happen at higher RPM, with higher oil flow rates, and when the oil is thicker (than necessary). This would be an operational window where there would be well in excess of what is required to maintain full film thickness, would it not? So is a little less flow, or maybe a lot less flow, (20%, 30%?) going to have that much of a drastic effect? I understand it is going to depend on specific examples to get an answer but can any typical example be given? Thoughts?
