This is regarding the Accord in my signature. Tire pressures have been fine until yesterday morning (have had a cold snap here.) TPMS light came on upon starting car. After 30 miles into commute, light went off (guess tires heated up enough to build pressure.) Light did not turn on coming home last night.
This morning, light came on upon start and stayed on for my entire commute (65 miles.) When I left work, light came back on again. Stopped and checked/filled tires (pressures matched specs, but I pumped all 4 tires to 32 PSI) and the light is still on. The manual says that light should not be on if overfilled, but it also says nothing (that I can see) about resetting the light.
Moments like these makes me wish I would have kept the old Taurus. Anyone have any knoledge of the system on this car?
