I haul about 400/500 pounds of equipment in my Sedona at all times, plus myself. The door placard states to run tires at 35 psi but, following my normal routine of filling the tires a tiny bit more, I have them all running at 38 psi. I actually have 3 different types of tires on the vehicle
The front axle currently has identical tires, with a 103 load rating. The rear tires, while non-matching, both carry a 101 load rating. All 4 tires have a maximum of 44 psi stated on the sidewall. I realize that 400/500 pounds isn't that much, and that a vehicle of that size is more than capable of hauling more people-weight that 400/500 pounds. Am I good staying at 38 psi?
