Originally Posted By: sunruh
that looks pretty wicked for a standup scooter!
what size cc?
The engine started off as Komatsu Zenoah 62cc. Then it received extensive head work, bottom end magic, and intake reeds.
any idea on hp?
Although never on a dyno, I was told by the engine builder and by the maker of the after market engine parts (Trevor Simpson), that this engine should put out close to 17HP on Methyl Alcohol.
how fast is 0-60? (OMG 60!!! on that??? pretty insane!)
The engine only has one gear....with a centrifugal clutch on the crankshaft, and a chain back to the rear sprocket. With it geared to max out at approximately 64MPH (where I typically had the gearing set at), I could hit 60MPH in about 4 seconds flat....if I could keep the front wheel down. This was feathering the throttle. If you could stay on it at WOT from a stand still (impossible to do), it would have hit 60 much faster than that.
and what is the top speed?
That depended on gearing. With that much power (17HP) and the scooter only weighing 22 pounds, top speed was only limited by gearing and how insane you were. I never had it faster than 70-72 MPH.
and how much armor do you wear (stormtrooper suit?) to go that fast?
Nothing crazy. Just full face helmet, leathers, and gloves with Kevlar sheets in the palms...most important.
steve [/quote]
Sunruh,
Yeah, it is a crazy machine.
