Quote:
[NHHEMI]
RP actually lists ATII among other GM fluids that the SM specifically replaces just as an FYI. Per usual the RP anti's only cherry pick info.
I formulate lubricants so what I am telling you is Auto-Trak II and RP Synchromesh
are NOT COMPATIBLE due to their DIFFERING formulations.
RP Synchromesh is a good MTL for MT's that need a lubricant with a 7.5 cSt fluid.
I am not anti anything. I attempt to educate people on lubricants. I push no product, I sell no product on BITOG.
Sorry if you don't like the truth, but many others may appreciate straight facts.
Quote:
If you could find the PDS you just as easily could have found the following trans fluid cross reference chart which has a link on the SM page where you found the PDS.
http://royalpurpleconsumer.com/wp-content/uploads/Transmission_Lubricant_Cross_Reference_Chart.pdf
All you have to do is scroll to the GM fluids and you will find where they specifically list SM as working with ATII. It is not "vague" as you characterize it. I expect no less though when RP is being discussed.
I did see that and thank you but I am quite capable of chasing Internet links.
Apparently you did not read my post very well. I was pointing to the PDS which WAS vague as I clearly stated in my previous post. I saw the cross reference listing earlier but do not agree with it.
Quote:
[NHHEMI]With the above said I still would NOT use SM to replace ATII as I posted earlier in this thread and especially so if a warranty is involved.
Why not, it sounds as if you have complete confidence that Auto-Trak II and SM are one and the same, so with that confidence you would be forced to use it during the warranty period.
Quote:
[NHHEMI] If no warranty and the person wanted to try it though why not? There are a lot of multi use fluids used by BITOGER's with excellent results so why not SM to replace ATII if RP says it works? Do we not believe them just because it is RP?
Because I do not believe RP has it correct, and no one has shown me that the two fluids under discussion are compatible.
Quote:
The GM product is called "Auto-Trak II" Transfer Case Fluid with part number #12378508.
It is for GM vehicles with automatic transfer cases.
The kinematic viscosity is 7.3 cSt@100C, which is approx. the same viscosity as DexIII/Mercon fluids.
It contains special additives for the transfer mechanisms in automatic transfer cases, and RP Synchromax is NOT the same animal.
Quote:
[NHHEMI]RP has specifically listed it as being a replacement. Is saying product X will replace product Y just marketing or is it truth? IMO if a company puts themselves out there like that, in writing, they are liable if it is not compatible. RP would not say it was if it wasn't or they would risk being sued.
I am not going to get into legalities of risk etc., but I know that SM and Auto-Trak II are NOT chemically compatible.
