Originally Posted By: Artem
Originally Posted By: otis24
My Dodge Grand Caravan has consumed oil since i purchased it new in 2005. It currently has 175k miles and has used synthetics since about 36k miles. My last oil change was with Mobil 1 HM. Usage was up to a full quart in the first 1200 miles. I topped it off. It has now been about 2000 miles and consumption has been nil.
That said, if you have a known issue, a HM oil might be helpful regardless of mileage. I would like to see someone else with a Grand Caravan with lower miles use this oil to see if it solves their consumption issue.
I'm curious as to what additive in Mobil 1's HM oil seemed to help your consumption...
My 2006 Scion tC with 110k miles on it has been BURNING any oil I tried at a rate of 1 quart per 3,000 miles easy. It doesn't leak anywhere, seeing as the entire engine bay is dry as a baby's bottom, after a diaper change.
Now, how in the world can a HM oil cure the consumption I'm experiencing with my engine? It's very obviously BURNING the oil due to piston ring design, as this is a very known problem with the 2AZ-FE blocks.
I expect HM oils reduce consumption for three reasons: 1) they tend to be a bit thicker than non-HM oils, 2) have more cleaning agents than non-HM oils, which could free-up stuck rings in a neglected engine and 3) can reduce leaks, including valve stem leaks which wont leave evidence in the engine bay or garage floor. They won't do much to offset a design flaw, though.
