Howdy again fellow Bitogers and a good afternoon to all:
On a previous post about my leaking radiator, one reply got me to thinking. Back in November of last year, my son was driving the world renown "Bluesmobile," (1993 Ford Taurus GL 3.0 V-6) when the upper radiator hose let go. He didn't notice and pegged the heat gauge. When he got it home, I installed a new upper hose and flushed the cooling system and all was well. But I noticed after that that at idle, the engine runs a little rough, like it has a slight irregular miss to it. I've run several kinds of injector cleaner though the fuel system with no improvement. Plugs, wires, cap, rotor and coil have all be replaced about 25,000 miles ago.
Going down the road is no problem for this car and it has plenty of power, although I noticed lately that it does "ping" under hard acceleration.
While there is no oil in the coolant and no coolant in the oil, is it possible I have a small leak in my head gasket that is causing the engine to idle rough?
Thoughts, opinions, ideas?
