My 2011 Cruze has 22K and I'm preparing to D&R the ATF at 25K.
There is a drain plug which will let me drain approximately half of the 9 quart total. I feel that getting 50% new fluid into the A/T has to be a good thing.
On the Cruze forum that I visit a GM tech claims that draining and replacing the fluid with the same amount that comes out will not give an accurate measurement and that a scanguage and level check while running is necessary. This would overly complicate things and make a dealer service call necessary. He claims that A/T is very sensitive to the correct level.
(The only way to check the level is underneath the car while running).
Does anyone have experience with this tranny (6T40E, I think)
I would think a couple of ounces either way wouldn't be a problem....what do you guys think?
PS: I plan on using Castrol DexVI which claims to be a semi-synthetic.
