Originally Posted By: alternety
The ability to make the material in large volume is fairly new. So far I have found only two sources I can specifically identify as the IF form being imported.
The maker/importer needs to get on the stick - not for my benefit, mind you, but to make or keep their product viable. A relatively new application such as this faces a double whammy: it's relatively unknown and most of the hype comes from ad-men, who may lack credibility.
Perhaps most important, it may only be incrementally better than existing products, such as MoS2. MoS2 is more well known, relatively inexpensive to produce and has a substantial literature regarding it's use. And even for MoS2, this forum notwithstanding, I have never seen evidence to support claims of fuel savings, and use in automotive engine oil is mostly supported by extrapolating other studies.
