Here is my UOA on my 2012 Accent. Thoughts?
BlackStone Comments:
This first sample from your Hyundai Accent looks great. We compared it to universal averages,
which show typical wear for this type of Hyundai engine after about 4,200 miles on the oil.
You didn't run quite that long, which accounts for some of the lower readings.
Still, everything was in good proportion, so we doubt any mechanical issues are at work.
The TBN was good at 3.5 since 1.0 or less is low.
The viscosity was on target for a 5W/20 and no contamination was found.
Try running about 5,000 miles on the next oil and check back.
PS- I am using a drop in K&N air filter.
Code:
MI/HR on Oil 3,177
MI/HR on Unit 35,813
Make Up Oil Added 0 qts
ELEMENTS IN PARTS PER MILLION
ALUMINUM 2
CHROMIUM 0
IRON 7
COPPER 1
LEAD 0
TIN 3
MOLYBDENUM 19
NICKEL 0
MANGANESE 0
SILVER 0
TITANIUM 93
POTASSIUM 0
BORON 82
SILICON 11
SODIUM 4
CALCIUM 2604
MAGNESIUM 12
PHOSPHORUS 861
ZINC 920
BARIUM 0
PROPERTIES Values Averages
SUS Viscosity @ 210°F 49.8 46-57
cSt Viscosity @ 100°C 7.22 6.0-9.7
Flashpoint in °F 385 >355
Fuel %
Antifreeze % 0.0 0.0
Water % 0.0
Insolubles % 0.3
TBN 3.5 >1.0
TAN
ISO Code
Code:
MI/HR on Oil 3,177
ALUMINUM 2
CHROMIUM 0
IRON 7
COPPER 1
LEAD 0
TIN 3
MOLYBDENUM 19
NICKEL 0
MANGANESE 0
SILVER 0
TITANIUM 93
POTASSIUM 0
BORON 82
SILICON 11
SODIUM 4
CALCIUM 2604
MAGNESIUM 12
PHOSPHORUS 861
ZINC 920
BARIUM 0
Fuel %
Water % 0.0
Insolubles % 0.3
TBN 3.5 >1.0
TAN
ISO Code
