BOBISTHEOILGUY
Thread starter
Brian, I thank you for the layout. It is exactly what I have/had in mind and now I've got a setup that will accommidate this test. I am getting ready to start this soon. I had to aquire a big enough motor to run this pump. My original system would not allow me to run the pump for more than about 30-50 secs before blowing the fuse.
I went a bought a 16spd drill press($150. + new motor) for this purpose only as I've never needed one. I then bought a like 3/4 reversible horse pwer motor as the pump rotates the oposite direction of a drill. After installing it, I then tried to set it up to bring 50lbs of input pressure on a blank filter(no media). The head pressure was so great the motor couldn't pass by 30-40lbs. So I went and upgraded the 3/4hp motor with a 2hp reversable motor on the same press. It now doesn't break a sweat getting up to 60lbs let alone 40-50. So, now the equipment is set, I will be getting back into retesting from start with set variables and no adjustment will be made one set. I plan on using the 40lb setting as I have 60lb gauges and want to make sure if we do have higher restictive filters then it will show up.
Temp is the only thing I have a problem with as I can setup some sort of heater but to heat oil to 200 degs will take some doing. The first run I do will represent an engine on start up( basic ambeiant temp). I do believe this will give some idea on how it will do. I'll put some more thought on the temp situation. I also have several used filters which has certain recorded miles so we will compare against a new filter of same brand. My thoughts on this is that most filters would need to be changed by 3k miles. Not because of junk in filter but due to hot and cold deteriation of filter media creating more restriction. Anyway, as you stated, this will show some interesting info one way or the other.
bob
[ September 07, 2003, 07:24 PM: Message edited by: BOBISTHEOILGUY ]
bob
