I've decarboned the 360 in the Jeep by running it at 2500 with the hose nozzle misting down the TB. It hardly notices, as long as you hold the revs up for a good 15 seconds after you stop spraying. Otherwise, it chokes a bit when you idle it down.
Hydrolocking a running engine, particularly at higher rpms, takes a surprisingly large amount of liquid. With flammable stuff that can start to evaporate, and then burn off, it's even a little harder.
When I seafoamed my Mom's Jeep with a 4.0 in it, I tried to stall it at the end by shoving the end of the 3/8" brake booster vacuum hose in the can. It choked a bit, but kept sucking, and kept running. And, it was only turning about 900 rpm. I ended up having to shut it down with the key. It ran for a good 5 seconds after I killed it too, running on just seafoam and compression ignition at what sounded like about 300 rpm.
