Originally Posted By: DMZ
My future daughter-in-law has a 1988 Acura Legend, 2.7l V6. She bought it for $800 w/147k miles on the odo. As part of my "keep it alive for a few more years" program, I would like to do a drain and fill on the AT. No owners manual, but I am thinking it took Dex II.
Any opinions on what might work in it?
That car is not even broken in yet. Keep it maintained and it'll last far longer than a few more years. I have 433k on my '87 manual trans coupe. Engine has never been apart.
You are correct with your assumption that Dexron II was spec'ed. Attached is the lubrication page from a 1987 coupe manual.
The tranny solenoids do get sticky from what I've read. They can be cleaned (DIY) should be need arise.
Don't worry about the head gaskets. You'll have more of an issue with the ABS system (if it has it). IMO, head gaskets is more of a 2nd Gen ('91-'95) issue than with 1st Gen Legends.
Please post some pics of the car. Would love to see it.
Link to some DIY's:
http://forums.acuralegend.org/g1-diys-t42.html
Lube Page from Factory Service Manual:
BTW, if you ever decide to drain and refill the PS system, make sure you use Honda spec'ed fluid only. Put anything else in there and it'll start leaking like a sieve.
