I am in the midst of changing the rear-end gear oil on my 4wd Tacoma. The manual spec says 4WD models and PreRunner 3.12 qt. (2.95 L, 2.60 Imp.qt.)
I am up to about 3.5 quarts, and it still hasn't spilled out of the fill port yet.
Should I follow the spec of 3.12, or fill until it spills out?
I did jack the car to one side, and then the other to make sure the old oil drained from the axle housing. Maybe that would account for it?
So, fill port or Toyota spec?
