Ive been buying 5qt jugs of oil for my truck since I've owned it. The capacity is 4.5qts leaving me a half quart after each oil change. It was on a steady diet of penz hm for a while and I've got about 2.5 quarts of that sitting on my shelf. My last oil change the store was out of my usual oil so I opted for some pyb instead; so there's another half quart. On a recent road trip I forgot to bring along my leftovers, just in case I needed it, so I picked up a quart of the unbeatably cheap mobil super 5000 to bring along. Just this last weekend I switched to ML to see I'd it helps with a barely noticeable leak I've been having that the penz hm didn't seem to help; there's another half quart.
Now I've got 4.5 quarts of 'leftovers' sitting unused in my shop that I'd really rather not waste. Would making a 'franken-oil' of sorts out of those 4 different oils be a kosher thing to do? All my truck has ever used has been 5w-30 and that's what my leftovers all are.
I think from now on I'm going to pour the half quart I won't be needing into the filler neck with the drain plug out just to flush things out and eliminate my issue of having a little extra oil. Unless it's wise to use oil that's been just sitting on a shelf for a couple years, then itll be like a 'buy 5 oil changes get the 6th for the price of a puro classic' type deal lol
If you haven't gathered already, no oil is burned between changes and a negligible amount is leaked, not even enough to require topping it up.
Opinions?
Opinions?
