Well, I went to HF to buy the motor. I talked with the guy there and while I know he's not the worlds authority on motor swaps. He did say It would be iffy to try and use that motor.Being I have no use for it if it doesn't work, I decided to abort the mission. I went home and started looking at a 4.5 hp B@S mower someone gave me. I don't use or need it, so I said why not. Took the motor off and measured it up against the original one. I would need some longer mounting bolts, and some spacers, as the shaft was about an inch longer. Went to Sears and got the hardware. Went over and bolted it up. I had to wire up the clutch brake so it would run. I added some gas and a few pulls later it was running. I had to raise the idle some or it wanted to quit. After that it was splitting time.I did a bunch of logs and for the most part it wasn't even straining. But if I did a big piece of oak, it would stall. But would start right back up.Just have to go at it easier then the softer stuff. For a $3 dollar repair I'm happy with the results. Thanks to all who replied.,,
