TechnoLoGs
Thread starter
Originally Posted By: yonyon
I assume it is registered in NJ and is not nitocably dripping anything while sitting still idling.
Beyond that it must appear to have a catalytic converter properly installed. It must not have excessive exhaust leaks preventing the inspector getting a proper sample of exhaust from the tailpipe. It must not be visibly smoking. It must not appear to be unsafe to drive up to the machine and test. It must pass a tailpipe test (hydrocarbons and carbon monoxide only) at idle and at 2500 RPM with no load. Your gas cap must pass a test.
The noise might get your rejected depending on who is doing the inspection. If you pay for a private shop to do it you'll probably get someone who knows that isn't anything dangerous. If you go to Parson's it's probably a 50/50 shot. As far as the tailpipe test goes... the standards aren't that tough. If the Blazer will fail the tailpipe test you probably have some pretty foul smelling exhaust and already know to expect it.
I like the private inspection idea. Where is "Parsons?"
No smokes, no drips, no foul smell exhaust (from this engine.)
Runs solid. is just that [censored] noise.
I just realized.. I'm legal in reg/ins/lic, so, it's not something that is a bad idea to drive...... yes?
Still looking for the bolt, too. I need to get it somewhere with more clearance ot properly look.
Is amazing the head hasnt snapped off that bolt by now.
But STATE inspection = FAIL, right? (Like, at inspection station)
