Has anybody used of heard of this stuff? It maintains it'll change Dexron/Mercon ATF to MerconV. Is it possible to change a dino to a blend with 1 oz per quart?
The ad says:
LUBEGARD M-V Automatic Transmission Fluid Supplement benefits:
Enhances Dexron/Mercon ATF to perform like a Mercon V type fluid.
For use in all automatic transmissions requiring a Mercon V type ATF.
Prevents & Eliminates Torque Converter Lock-Up Shudder.
Prevents overheating and fluid oxidation.
Saves Time, Money and Space by eliminating the need to stock Mercon V ATF.
Keeps valves free. Also frees stuck valves.
Dramatically reduces friction & wear on metal parts and internal components.
Improves low temperature shifting.
Stabilizes the life of the fluid, thus extending service intervals.
Softens harsh shifts.
Extends fluid & component life.
Will not harm yellow metals.
Will not alter the crucial phosphorus or sulfur balance in your transmission fluid.
Contains absolutely NO Zinc
The ad says:
