[quote=demarpaint]You guys using FF, can you do a complete job with the spray bombs, or is buying the gallon and a gun for applying it the best way to go? Thanks. [/quote]
It depends on your individual situtation.
For 5 years, I took my vehicle to a collision shop that sprayed it with something similiar to Fluid Film.
Year 6, I saw that I still had good coverage.
I then bought a case of Fluid Film (aerosoil cans) and just did touch-up.
I have the gallon can, but brushing it on large areas can be messy.
I don't know the technical term, but Fluid Film will thin out when brushed on.
A few minutes later it will go back to its original viscosity.
My nephew uses a spray gun and is happy.
Your method of application would depend on:
1) Ease of getting under your vehicle
2) How fussy you want to be
3) Where you will do the spraying,
Clean driveway - watch out for drips
Vacant lot - go crazy
I live in Buffalo NY ...... We get snow ...... The roads are salted.
My vehicle is 11 years old ...... I have NO rust that I can see.
Also, I do a thourgh job in the Fall, and then touchup in the Spring.
