A co-worker of mine has a 2010 Fusion 2.5L that is just out of warranty. His wife drives it, and has begun to sputter and cut off at somewhat regular intervals. This is apparently usually accompanied by a check engine light. He had AutoZone scan it and it's a P2111. The throttle body is apparently under investigation by NHTSA and parts are back-ordered by Ford.
Can any Ford technicians on here offer some advice? Have you seen this on cars brought in before and is replacement of the throttle body really the fix? Has Ford re-designed the throttle body, or would a new one eventually suffer the same fate as the original one? It's a 2010 and is out of warranty.
