have about 20° of steering wheel slop and it's caused by the 3/8" clevis pin that connects the steering cable end in the top picture to the steering lever part #14 in the bottom picture. looking for thoughts on how to fix it and get rid of the slop. I've checked the steering lever in the transom and that's solid. And the teleflex rack & pinion steering at the helm and cable are all in perfect condition, there is no play in the rack. it's all at the clevis pin where the cable connects to the steering lever.
drill it out and use a 7/16" pin ?
are throw a bushing or shim around the existing setup?
i measured the clevis pin and looking at it doesn't seem to be worn, it's around 0.370", so i'm not sure if a new pin would fix it. and couldn't measure the holes in the steering cable or lever easily.
