2006 Civic.
Sometimes going over abrupt bumps on the road, I would hear this metallic thunk that seems to be coming from front end.
However, if I am driving fast(say highway) and go over normal bumps, everything seems fine.
Jacked up front end and checked for play in tierods/ball joints by wiggling wheels. There are none.
Grabbed onto stabilizer links and try wiggling, didn't move much. However, I noticed the two sides don't quite look the same. I was wondering if it could be the possible problem. I hear it more on the driver side.
Here's the passenger side:
Here's the driver side:
Is it my imagination or does it look like driver side is a bit bent? Should both sides look identical and like passenger side?
