Seems from another post, there are many opinions on how to properly patch a leaky tire. It got me to thinking about creative tire patches I and others have used in the past.
More than once, when patching an inner tube on a tractor or truck, I have patched the leak with Duct Tape - it worked amazingly well. The pressure of the tube pressing against the tire held the duct tape in place nicely and I've had these kinds of patches last for years, (especially on tractor tires).
One time I broke the valve stem off while driving "off road." I wasn't hot-rodding, simply pulled too close to a tree with low branches and one of these branches broke the valve stem completely off but left the "base" of the valve stem in place. I had a little 12 volt pump and had kept the different "fittings" that come with the pump. I took a self tapping sheet metal screw, wrapped it with electrical tape, and had that ready to go. I then put one of the pump fittings, (the one that looks like a little pipe), and held it against the valve base and inflated the tire. When it had about 30 pounds pressure, I quickly ran the sheet metal screw wrapped with electrical tape into the valve stem base. It worked so well I drove on it for about a week before fixing it properly.
A similar situation happened about two years ago on the now world famous "Luv" machine - pulled too close to an orange tree and busted the valve stem off at the base. It didn't break it off entirely but left it hanging on the wheel. I took my pocket knife, cut the valve stem off while leaving the base of the valve stem still in the wheel. I then whittled the rubber off half the valve stem down to the metal center and cut a smooth joint on the valve stem rubber to join with the rubber on the valve stem base. Next, I coated the metal part of the valve stem in rubber cement and gently worked it into the valve base and let it sit for about 20 minutes. Aired it up and it holds air to this day.
And finally, my nephew is a roofer by trade. He does torch down roofs and one day on the job, a nail punctured the sidewall of the tire on his truck. He pulled the nail out, put a piece of roofing material over the hole, torched it, aired the tire back up and drove probably 20 miles to the tire store for a new tire. I told him he should have kept driving on it to see how long it would have held.
Anyone else have any amazing patch stories to share for future emergency situations?
