Here you go, Fram PH7317. I think its a decent filter for a 3K OCI. But I would run a Classic over this. On the other hand, I would run a TG over a P1.
Glued seam...
All the way around...
The ADBV felt ok, I think the Classic has a better nitrile ADBV though.
Bypass valve felt the same as the TG.
Bottom glue job...
Top glue job..
Again, not a BAD filter, not great either. I would run a Puro Classic over this, but I would run a Tough Guard over the Pure One.
Glued seam...
Bottom glue job...
Top glue job..
