so as i have posted before i had an issue in the shift quality (slight jerk between shifts) in my 2000 toyota celica gts auto, i did the 3x drain n refill method (usually done everytime i buy a used car without maintenance records other the carfax) so from all that i have read on BITOG and Amsoil website, i have decided to give (Signature Series Multi-Vehicle Synthetic Automatic Transmission Fluid) a shot in the hopes of improving shift quality (smooth as silk!), i added 4quartz 1st drain n refill, then 2quartz (2nd), and finally 1.8quartz(3rd) ATF dipstick still read over...(toyota manual says 4.2 quartz per drain n refill and i call [censored] on it) and between each drain n refill the car was driven at least 50 miles to to ensure the fluid reached operating temperature and circulated through each gear, is the current method i am using effective in changing most of the ATF out of the AT or is there another method? i refuse to get it flushed as 2 of my AT failed after flushes (9 months later for whatever reason it could be). So what i am attempting a good idea? will it change my shift quality (from castrol import to amsoil atf)? i am also planning on changing the transmission filter, and is adding a transmission cooler a good idea on my little AT? or is that usually for higher HP and towing situations?
Thank You any suggestions.
