Originally Posted By: asiancivicmaniac
Originally Posted By: J. A. Rizzo
The crud is going to build up regardless of how often you change the fluid. Wear happens no matter what we do. So why upset the balance by stirring it up with multiple changes and letting that stuff get circulated around to get ground into the gears and stuck in the hydraulics? Just leave it where it is and don't worry about it. If there's no problem to solve, why invent one?
And you think leaving micro-particles inside as an abrasive would be better?
No, I'm saying you're speculating and creating Fear, Uncertainty, and Doubt where none should exist. I postulate that nobody's transmission grenaded prematurely because they didn't change the fluid when the manufacturer said they didn't need to. My point is to expose you as just another "some anonymous person on the Internet" who has no idea what he or she is talking about but talks anyway despite the fact that engineers have worked for countless hours on the design of the powertrain and its lubrication schedule. Don't those "micro-particles" you imagine abrade the mechanism during the warranty period? Why would the manufacturer let this happen?
Provide some evidence of the problem or it doesn't exist. Show us that changing the fluid despite the manufacturer's recommendation results in a cost savings or transmission lifetime improvement. Count all the particles you want - I don't disagree they're present - speculate all you want about problems they cause. Just because they exist doesn't mean the transmission lifetime is affected, and if you clean them out with white gloves, there's no evidence it makes anything last longer. There's no evidence of a problem except in your imagination, so stop trying to solve one. It's a waste of time, needless money in some petroleum executive's bonus fund, and someone else's hard-earned money.
