I recently acquired a 1988 Ford Thunderbird with a 3.8l v6 with 65,000 miles from my wife's grandparents. Upon receiving the vehicle, it had not been started for at least 2 years (that we know of) and it would crank but never start. So, after seeing that it would not start I replaced the spark plugs, spark plug wires, fuel pump, fuel pump relay, battery, alternator, and belts. After replacing everything it fired right up and ran pretty well except for the fact that it randomly acts as if it's running out of fuel at idle or up to speed. I have put a fuel pressure gauge on the rail and on turning the key it shows 40psi, at idle it's about 32psi, however when I give it a little bit of gas for a few seconds it drops to 25-27psi and then the gauge jumps between 30-34psi after I let off the gas. Is it normal for the pressure to drop that much when I am barely pushing on the gas in park? Any help or suggestions would be appreciated.
