Hi Folks... Been a fan of BITOG for years and have learned plenty. Now I finally have a question that I don't think has been raised yet...?
Unfortunately, I don't know how to upload a couple pictures of my issue but I DO have some nice pics.. (learning curve for me in here - can someone direct me? I don't understand what BITOG's FAQ is telling me to do)
OK...
My daughter's '98 accord 2.4L has 187,600 +/- on it. Bought it used in '09 at 150,000 miles with decent service records. Her usage of the car is a lot of short hops with the occasional 140 r/t to her boyfriend's house - mainly highway... about 2 times a month. She does warm the car up for 5+ minutes in the morning before heading on her way
Since we've owned the car, I've religiously changed the oil along w/ filter - first at 5k intervals and, as of 175k, 3k intervals with Mobil 1 0W-30. At 187k I used Penzoil HM 10W-40 which I think I'm going to regret
I changed the PCV at 170k and again with this last oil change (plenty of vacuum)
Last year, while at college, her radiator developed a leak and it was a few months before I had he car long enough to replace it. Not aware of any killer over-heating, but it was running hot.. no question
Some months after that, the car starting using oil... never blew out the tail pipe... never any drops or puddles in the driveway... Just disappeared. It reached a point where she was a qt low at 1,000 - 1,200. At some point last fall (175k) her check engine light came on because the oil level dropped so low (didn't know that could actually happen). I immediately changed the oil and filter and changed OCI to 3k
Lots more to talk about with regard to the oil and ticking (now knocking) but this is getting too long - especially for a first-post
My immediate issue is this:
Been reading with a LOT of interest the use and MMO and Kreens. Decided to place 6 oz of MMO in the fuel tank prior to a fill-up this weekend (17 gal tank) and it took only about 3+ gals to fill it. Figured it would mix nicely and I could continue this regime going forward. Then I remembered that there was still 3/4 tank with a Lucas UCL dose in there.
So now, with 50 miles on the car, I have a lot of stuff added to that Shell gas... Car reacts to the gas pedal nicely and, of and by itself, I can't say I can even tell - so no harm no foul?
With regard to the knocking above, I was searching the net for some insight and learned that sometimes a loose spark plug could cause an engine to knock. Hit it first thing this morning and was amazed at the colorization of the plugs - they have a reddish coating on them - all over the porcelain and the electrodes. These plugs were installed a month ago and have less than 3,00 miles on them (NGK G's). Like I said, I have great pics but can't figure out how to upload them
I just got back from AAP and picked up another set of NGKs but before I throw them in I wanted to bounce it around here. Mentioned it the AAP guy and he blamed the MMO for the red color...? I find that hard to believe, especially after only 50 miles but...?
Any ideas...? Again the pictures tell a better tale, but I've never seen a spark plug come out looking like this. They are totally intact (electrodes were fine and no cracks or anything) it's just that crazy color. And it isn't powdery nor does it flake off. A reddish/brown that was baked on. I could scratch some off with my finger nail but other than that, that stuff is on there
Any thoughts? Can't wait to get some input from you guys - thank you in advance
This is my first post and I am so sorry that it's reading like a novel, but I wanted to give you some background on the car and still have lots more to discuss ... (God help you)
Thank you
OK...
Thank you
