Hi,
only a few days until my ARX order arrives
Well in the meantime I have a little doubt concerning how ARX acts with the engine parts. Thanks to this site, I now know that most of the engine wear occurs at startup. Many engine oils are advertised as being somewhat "polar" so that they are able to cling to the cylinder walls and protect on cold start. As far as I remember, ARX is best used with dino oil since ARX itself is a bit polar and dino is less polar than synthetics right so ARX has not to compete for the "polarness", right? I suppose that as ARX cleans the engine, it removes any "oil coating" in the engine too. If it does, wouldn't it be resulting in more engine wear??? This is not too much of a concern for the cleaning phase since it's only 1500 miles but I plan to use the maintenance dose in the future, and then if ARX removes any oil coating prior to each startup, it should cause more engine wear in the long run no?
I know that this is certainly not a problem and I think UOA have shown no additional engine wear when using ARX but I'd just try to understand the basics behind this. How would it be possible to remove oil sludge and cleaning the engine yet leaving an oil coating on cylinder walls to prevent startup wear???
Thanks
Thanks
