The first mechanical brake down on the 2004 Honda S2000 ! The clutch master cylinder has a leak inside the firewall dripping down inside the car, the reservoir fluid was almost empty and the clutch only engaged when it is completely depress and dis-engaged when released less than 1".
How hard is it to replace the clutch master cylinder in a S2000 ? Looks like not much room behind the clutch pedal to remove the 2 nuts that hold the MC to the firewall, also no room to remove large pin ("yoke pin") and the cotter pin that connect the MC to the clutch pedal.
