Originally Posted By: fdcg27
If you don't know when the water pump, timing belt and tensioner were last changed, put that task at the top of your to-do list.
Once that service is done, you'll be good to go for as long as you're likely to own this car.
Don't find out the hard way that you should have done this work, either.
This Honda engine isn't going to care too much about oil or filter choice.
Most Hondas don't and you do live in a climate where real cold is not a consideration.
Use any conventional 5W-30 on 5K drains or any syn on 7.5K drains.
Honda did recommend 7.5K or one year on any API SG 5W-30 when your car was new, so these should be very conservative intervals.
I hope you enjoy many miles of happy ownership.
In this generation of Honda product, you probably will.
really? teggy's are not picky about oil? and I havent heard anyone metion castrol?
