This is a pet peeve of mine; I’m not sure why…presumably it’s because so few get it right.
A gauge is supposed to be labeled with what that that gauge is displaying. A speedometer is labeled MPH; literally, because it tells you Miles Per Hour. A voltmeter is labeled V; literally because it tells you Volts. An oil pressure gauge is usually labeled PSI (or sometimes kPa); literally, because it tells you Pounds per Square Inch.
Why, then, are most tachometers labeled RPM x 1000? The gauge does not give you Revolutions Per Minute multiplied by 1000. Revolutions Per Minute multiplied by 1000 would read 700,000 on most cars. The gauge, in fact, gives you Revolutions Per Minute divided by 1000; the correct label is RPM / 1000 or something to that effect.
The only one I’ve seen done correctly is in an old Chevelle, which was RPM / 100 (for a tachometer that counts 10, 20, etc).
Does anyone here own a tachometer that is labeled correctly? Neither of mine are.
