After 2 1/2 years I decided to change the oil. My OLM was down to 5%, I had driven through numerous dust storms and followed many trucks down dirt roads eating clouds of dust. I also had over 4000 miles of towing 2 different travel trailers (one weighing 6500 lbs and the other weighing 8500 lbs), so I thought it was time. Blackstone said I could have kept going. Copper was a little high but I am sure that was from copper leaching on the hot mountainous pulls with the trailers.
Code:
MI/HR on Oil 9370
MI/HR on Unit 43477
Sample Date 7/1/2013
Make Up Oil Added 2.5 Quarts
ALUMINUM 2
CHROMIUM 0
IRON 15
COPPER 42
LEAD 2
TIN 2
MOLYBDENUM 1
NICKEL 0
MANGANESE 0
SILVER 0
TITANIUM 0
POTASSIUM 3
BORON 55
SILICON 10
SODIUM 4
CALCIUM 1310
MAGNESIUM 941
PHOSPHORUS 1113
ZINC 1369
BARIUM 0
SUS Viscosity @ 210°F 71.1
cSt Viscosity @ 100°C 13.25
Flashpoint in °F 445
Fuel %
Antifreeze % 0
Water % 0
Insolubles % 0.3
TBN 4.9
TAN
ISO Code
ROD: Thanks for the notes. It looks like taking the last of the drain didn't hurt anything. We do have some extra copper here, though that's probably not a result of your sampling technique. It does show some extra wear at brass/bronze parts. High copper in these engines isn't uncommon, so we're not going to get too worked up about it after just one sample, especially since everything else looks god. The TBN was strong at 4.9 and the air filter kept silicon low despite the dust storms. Do another 9,000 miles or so and check back on copper.
Code:
MI/HR on Oil 9370
MI/HR on Unit 43477
ALUMINUM 2
CHROMIUM 0
IRON 15
COPPER 42
LEAD 2
TIN 2
MOLYBDENUM 1
NICKEL 0
MANGANESE 0
SILVER 0
TITANIUM 0
POTASSIUM 3
BORON 55
SILICON 10
SODIUM 4
CALCIUM 1310
MAGNESIUM 941
PHOSPHORUS 1113
ZINC 1369
BARIUM 0
Fuel %
Antifreeze % 0
Water % 0
Insolubles % 0.3
TBN 4.9
TAN
ISO Code
