JHZR2
Staff member
Hi,
I have some play in the tie rod end on the right front of my 81 240D. It is an original tie rod, the permanently sealed boot worked for 75k miles and 30 years.
These are 16mm threads, while many of the aftermarket complete replacements are 14mm.
My reading indicates that many cars were delivered with different right and left tie rod assemblies, so that when aligning, both sides could be turned the same way to get the same effect. Is that true (not just with Mercedes, but overall)?
If I need a right front outer tie rod, what is the likely thread that is required, right hand or left hand? I dont exactly have a machine to go play on this.
Tie rod ends are about $13 each for no-name, and Made in Germany Lemfoerders are around $23, but are only available in 14mm. A complete tie rod (two ends and center coupling) is around $41.
Not sure if 16mm vs 14mm matters, though I guess 16mm is stronger and heavier.
Thanks!
Thanks!
