Originally Posted By: yonyon
Originally Posted By: TechnoLoGs
We replaced VSS, now speedo don't work.
Re-doing, soon.
-you didn't push something in all the way
or
-the gear fell off
or
-somehow you broke the end off of the cable
Of note, this new VSS:
1. Holds 1st gear all the way until redline; Can't give you an MPH on when it shifts, but then it shifts nice and easy.
2. Then Second takes awhile to get to 3rd, but 3rd and OD feel good.
I can absolutely feel a change from the old one, which was the original VSS from Ford (has Ford logo on it) and made rough, jerky, interesting shifts. That poor trans. it is holding up soo well.
Here are three pictures:
Here are three speed sensors, which I now have. The one in the middle is from an AX4N; The old one is on the right. (The fourth, which I described its behavior, is in the car.)
Aerial view.
Here is before it went back in the car, and I had no speedo.
And here is the apparatus used to loosen the nut.
And, down in there.
Here is what it looked like while we did the dirty deed.
